Sony Vaio SVE171C11L Motherboard Replacement
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: step 1, image 1 of 2 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: step 2, image 1 of 2 Sony Vaio SVE171C11L Motherboard Replacement: step 2, image 2 of 2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: step 3, image 1 of 2 Sony Vaio SVE171C11L Motherboard Replacement: step 3, image 2 of 2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: step 4, image 1 of 1
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: step 5, image 1 of 3 Sony Vaio SVE171C11L Motherboard Replacement: step 5, image 2 of 3 Sony Vaio SVE171C11L Motherboard Replacement: step 5, image 3 of 3
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
Edward Briseno
896 Reputation
6 Guides authored
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Member of CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 30
All Time: 371
