Sony Vaio SVF15A16CXB Battery Replacement
  1. Sony Vaio SVF15A16CXB Battery Replacement, Back Panel: step 1, image 1 of 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Battery Replacement: step 2, image 1 of 2 Sony Vaio SVF15A16CXB Battery Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Battery Replacement: step 3, image 1 of 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Battery Replacement: step 4, image 1 of 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB Battery Replacement, Battery: step 5, image 1 of 1
    • Unscrew the four 6mm screws with the Phillips #0 screwdriver.
  6. Sony Vaio SVF15A16CXB Battery Replacement: step 6, image 1 of 1
    • Lift the battery and remove it from the laptop.
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 30
All Time: 2,815
