Sony Vaio SVS151190X Disk Reader Replacement
  1. Sony Vaio SVS151190X Disk Reader Replacement, Hard Drive: step 1, image 1 of 1
    • Using a #1 Phillips screwdriver, remove the two 5mm screws as directed.
    • Slide off the back cover.
    • Ensure different sized screws are kept separate during disassembly.
  2. Sony Vaio SVS151190X Disk Reader Replacement: step 2, image 1 of 1
    • Remove the four 3mm screws using the Phillips #1 screwdriver.
  3. Sony Vaio SVS151190X Disk Reader Replacement: step 3, image 1 of 1
    • Lift out the hard drive and unplug the orange ribbon wire.
  4. Sony Vaio SVS151190X Disk Reader Replacement, Disk Reader: step 4, image 1 of 1
    • To loosen the keyboard, remove the twenty 5mm screws using the Phillips #1 screwdriver.
  5. Sony Vaio SVS151190X Disk Reader Replacement: step 5, image 1 of 1
    • Flip the device over and open it up.
    • Using a plastic opening tool and opening picks, pry off the keyboard from the bottom cover. Start from one of the corners of the device and work your way around.
    • The bottom cover is somewhat fragile, do not be too forceful when prying off the keyboard.
  6. Sony Vaio SVS151190X Disk Reader Replacement: step 6, image 1 of 2 Sony Vaio SVS151190X Disk Reader Replacement: step 6, image 2 of 2
    • The ribbon wire that attaches the keyboard and bottom cover is fragile, take care during removal.
    • Remove the keyboard from the bottom cover and place it down as demonstrated.
    • Carefully pull the plastic tab and remove the ribbon wire.
  7. Sony Vaio SVS151190X Disk Reader Replacement: step 7, image 1 of 2 Sony Vaio SVS151190X Disk Reader Replacement: step 7, image 2 of 2
    • Slightly pull up the black tape covering the disk drive's ribbon wire.
    • Pull up the blue plastic strip attached to the ribbon wire and remove the ribbon wire from the port.
    • Detach the ribbon wire from the fan so the disk reader can be removed.
  8. Sony Vaio SVS151190X Disk Reader Replacement: step 8, image 1 of 1
    • Remove the two 3mm screws using the Phillips #1 screwdriver.
  9. Sony Vaio SVS151190X Disk Reader Replacement: step 9, image 1 of 2 Sony Vaio SVS151190X Disk Reader Replacement: step 9, image 2 of 2
    • Take out the black plastic covering.
    • Remove the disk reader.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 673
