Sony Vaio SVS151190X RAM Replacement
Patrick Lee
Patrick Lee and 3 other contributors
Last updated on January 21, 2022
10 - 15 minutes
Easy
Introduction
Go to step 1
We will be replacing the RAM in a Sony Vaio SVS151190X laptop. If the device is running slow, it may be time for a RAM replacement. If your device is running slow, even with very few programs running you may need a replacement. Installing a higher quality RAM stick will allow the device to handle more programs running at the same time, as well as run high demand games. Before buying a new RAM stick ensure your device’s operating system and drivers are updated. You may not need to buy/install more RAM if the problem can be fixed with some software updates.
Tools
  1. Sony Vaio SVS151190X RAM Replacement, RAM: step 1, image 1 of 1
    • Using a #1 Phillips screwdriver, remove the two 5mm screws.
    • Slide off the back cover.
  2. Sony Vaio SVS151190X RAM Replacement: step 2, image 1 of 2 Sony Vaio SVS151190X RAM Replacement: step 2, image 2 of 2
    • The RAM is secured by two arms. Push the two arms outward with the Opening Picks or any appropriate substitute to release the RAM stick.
    • Remove the RAM from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 433
