Sony Vaio SVT151A11L Multimedia Card Replacement
  1. Sony Vaio SVT151A11L Multimedia Card Replacement, Battery: step 1, image 1 of 2 Sony Vaio SVT151A11L Multimedia Card Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Multimedia Card Replacement: step 2, image 1 of 3 Sony Vaio SVT151A11L Multimedia Card Replacement: step 2, image 2 of 3 Sony Vaio SVT151A11L Multimedia Card Replacement: step 2, image 3 of 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: step 3, image 1 of 3 Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: step 3, image 2 of 3 Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: step 3, image 3 of 3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L Multimedia Card Replacement: step 4, image 1 of 3 Sony Vaio SVT151A11L Multimedia Card Replacement: step 4, image 2 of 3 Sony Vaio SVT151A11L Multimedia Card Replacement: step 4, image 3 of 3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L Multimedia Card Replacement, Multimedia Card: step 5, image 1 of 1
    • Get unobstructed access to the multimedia card.
  6. Sony Vaio SVT151A11L Multimedia Card Replacement: step 6, image 1 of 2 Sony Vaio SVT151A11L Multimedia Card Replacement: step 6, image 2 of 2
    • Unscrew the two 2mm screws from the board using JIS #0 screwdriver.
  7. Sony Vaio SVT151A11L Multimedia Card Replacement: step 7, image 1 of 2 Sony Vaio SVT151A11L Multimedia Card Replacement: step 7, image 2 of 2
    • Lift up multimedia card.
    • Pull out ribbon cable from connected board.
Namuundari Zorigtbaatar
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 675
