Sony Vaio Tap 11 Screen Assembly Replacement
  1. Sony Vaio Tap 11 Screen Assembly Replacement, Screen Assembly: step 1, image 1 of 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Screen Assembly Replacement: step 2, image 1 of 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Screen Assembly Replacement: step 3, image 1 of 2 Sony Vaio Tap 11 Screen Assembly Replacement: step 3, image 2 of 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
3 other people completed this guide.
Alexander Bridges
1,217 Reputation
7 Guides authored
IUPUI, Team 1-2, Harley Fall 2015 Member of IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 2,633
