Sony Vaio VGN-FS640 RAM Cover Replacement
  1. Sony Vaio VGN-FS640 RAM Cover Replacement, Battery: step 1, image 1 of 1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Cover Replacement: step 2, image 1 of 1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Cover Replacement: step 3, image 1 of 2 Sony Vaio VGN-FS640 RAM Cover Replacement: step 3, image 2 of 2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: step 4, image 1 of 2 Sony Vaio VGN-FS640 RAM Cover Replacement, RAM Cover: step 4, image 2 of 2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Cover Replacement: step 5, image 1 of 3 Sony Vaio VGN-FS640 RAM Cover Replacement: step 5, image 2 of 3 Sony Vaio VGN-FS640 RAM Cover Replacement: step 5, image 3 of 3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
Brian Marchini
293 Reputation
2 Guides authored
Cal Poly, Team 24-32, Regan Spring 2010 Member of Cal Poly, Team 24-32, Regan Spring 2010
CPSU-REGAN-S10S24G32
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 4,861
