Sony Vaio VGN-S260 Keyboard Replacement
  1. Sony Vaio VGN-S260 Keyboard Replacement, Battery: step 1, image 1 of 3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: step 1, image 2 of 3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Keyboard Replacement: step 2, image 1 of 2 Sony Vaio VGN-S260 Keyboard Replacement: step 2, image 2 of 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: step 3, image 1 of 2 Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: step 3, image 2 of 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Keyboard Replacement: step 4, image 1 of 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Keyboard Replacement: step 5, image 1 of 2 Sony Vaio VGN-S260 Keyboard Replacement: step 5, image 2 of 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Keyboard Replacement: step 6, image 1 of 2 Sony Vaio VGN-S260 Keyboard Replacement: step 6, image 2 of 2
    • Lift up lever underneath the ribbon to detach the keyboard.
Jeffrey Bryan
570 Reputation
11 Guides authored
Cal Poly, Team 16-4, Maness Spring 2010 Member of Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Members
30 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 5,517
