Sony Vaio VGN-S260 RAM Replacement
  1. Sony Vaio VGN-S260 RAM Replacement, Battery: step 1, image 1 of 3 Sony Vaio VGN-S260 RAM Replacement, Battery: step 1, image 2 of 3 Sony Vaio VGN-S260 RAM Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 RAM Replacement: step 2, image 1 of 2 Sony Vaio VGN-S260 RAM Replacement: step 2, image 2 of 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 RAM Replacement, RAM: step 3, image 1 of 2 Sony Vaio VGN-S260 RAM Replacement, RAM: step 3, image 2 of 2
    • With the laptop still flipped over with the Vaio logo facedown, locate the screws for the RAM
    • Remove the screws
  4. Sony Vaio VGN-S260 RAM Replacement: step 4, image 1 of 1
    • Lift off the unscrewed cover
    • Locate the RAM
  5. Sony Vaio VGN-S260 RAM Replacement: step 5, image 1 of 3 Sony Vaio VGN-S260 RAM Replacement: step 5, image 2 of 3 Sony Vaio VGN-S260 RAM Replacement: step 5, image 3 of 3
    • Locate tabs next to RAM
    • Pull the 2 tabs away from the RAM
    • The RAM should pop up.
  6. Sony Vaio VGN-S260 RAM Replacement: step 6, image 1 of 1
    • Gently slide the RAM up and out
Jeffrey Bryan
570 Reputation
11 Guides authored
Cal Poly, Team 16-4, Maness Spring 2010 Member of Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Members
30 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 3,724
