Sony Vaio VGN-S260 Upper Casing Replacement
  1. Sony Vaio VGN-S260 Upper Casing Replacement, Battery: step 1, image 1 of 3 Sony Vaio VGN-S260 Upper Casing Replacement, Battery: step 1, image 2 of 3 Sony Vaio VGN-S260 Upper Casing Replacement, Battery: step 1, image 3 of 3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Upper Casing Replacement: step 2, image 1 of 2 Sony Vaio VGN-S260 Upper Casing Replacement: step 2, image 2 of 2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Upper Casing Replacement, Keyboard: step 3, image 1 of 2 Sony Vaio VGN-S260 Upper Casing Replacement, Keyboard: step 3, image 2 of 2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Upper Casing Replacement: step 4, image 1 of 1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Upper Casing Replacement: step 5, image 1 of 2 Sony Vaio VGN-S260 Upper Casing Replacement: step 5, image 2 of 2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Upper Casing Replacement: step 6, image 1 of 2 Sony Vaio VGN-S260 Upper Casing Replacement: step 6, image 2 of 2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Upper Casing Replacement, Upper Casing: step 7, image 1 of 1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Upper Casing Replacement: step 8, image 1 of 3 Sony Vaio VGN-S260 Upper Casing Replacement: step 8, image 2 of 3 Sony Vaio VGN-S260 Upper Casing Replacement: step 8, image 3 of 3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Upper Casing Replacement: step 9, image 1 of 1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Upper Casing Replacement: step 10, image 1 of 3 Sony Vaio VGN-S260 Upper Casing Replacement: step 10, image 2 of 3 Sony Vaio VGN-S260 Upper Casing Replacement: step 10, image 3 of 3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Upper Casing Replacement: step 11, image 1 of 1
    • Remove the upper casing.
2 other people completed this guide.
Jeffrey Bryan
570 Reputation
11 Guides authored
Cal Poly, Team 16-4, Maness Spring 2010 Member of Cal Poly, Team 16-4, Maness Spring 2010
CPSU-MANESS-S10S16G4
4 Members
30 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,857
