Sony Vaio VPCCW17FX Hard Drive Replacement
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: step 2, image 1 of 1
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: step 3, image 1 of 2 Sony Vaio VPCCW17FX Hard Drive Replacement: step 3, image 2 of 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: step 4, image 1 of 2 Sony Vaio VPCCW17FX Hard Drive Replacement: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: step 5, image 1 of 3 Sony Vaio VPCCW17FX Hard Drive Replacement: step 5, image 2 of 3 Sony Vaio VPCCW17FX Hard Drive Replacement: step 5, image 3 of 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: step 6, image 1 of 3 Sony Vaio VPCCW17FX Hard Drive Replacement: step 6, image 2 of 3 Sony Vaio VPCCW17FX Hard Drive Replacement: step 6, image 3 of 3
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
Tiffani Beck
219 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 1,652
