Sony Vaio VPCCW17FX Webcam Replacement
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: step 1, image 1 of 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: step 2, image 1 of 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: step 3, image 1 of 2 Sony Vaio VPCCW17FX Webcam Replacement: step 3, image 2 of 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: step 4, image 1 of 2 Sony Vaio VPCCW17FX Webcam Replacement: step 4, image 2 of 2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: step 5, image 1 of 2 Sony Vaio VPCCW17FX Webcam Replacement: step 5, image 2 of 2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: step 6, image 1 of 3 Sony Vaio VPCCW17FX Webcam Replacement: step 6, image 2 of 3 Sony Vaio VPCCW17FX Webcam Replacement: step 6, image 3 of 3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
Tiffani Beck
219 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,171
