Sony Vaio VPCF115FM Back Panel Assembly Replacement
  1. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: step 1, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so the bottom is facing up.
  2. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 2, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 2, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 2, image 3 of 3
    • Unlock the left tab on the battery.
    • Glide the right battery tab to release the battery pack from the laptop.
    • Keeping the battery tab in the released position, lift the battery up.
  3. Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: step 3, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, RAM: step 3, image 2 of 2
    • Remove the 9mm Phillips #1 screw located on the back cover.
    • Remove cover.
    • Push out metal tabs.
    • Remove card.
  4. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Hard Drive: step 4, image 1 of 1
    • Remove two 9mm Phillips #1 screws.
  5. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 5, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 5, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 5, image 3 of 3
    • Remove the panel.
    • Gently remove the hard drive.
    • Remove screws securing caddy to hard drive.
  6. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: step 6, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Disk Drive: step 6, image 2 of 2
    • Remove the 9mm Phillips #1 screw holding the disk drive in place.
    • Remove the 9mm screw near the memory stick.
  7. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 7, image 1 of 1
    • Using an iFixit opening tool, carefully pry the disk drive away from the device.
  8. Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: step 8, image 1 of 2 Sony Vaio VPCF115FM Back Panel Assembly Replacement, Back Panel Assembly: step 8, image 2 of 2
    • Remove three 3mm Phillips #1 screws on the side panel.
  9. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 9, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 9, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 9, image 3 of 3
    • On the top of the panel, remove four 3mm Phillips #1 screws.
  10. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 10, image 1 of 1
    • Remove the rest of the twelve 9mm Phillips #1 screws on the back panel.
    • Remove the final screw.
  11. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 11, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 11, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 11, image 3 of 3
    • Using an iFixit opening tool, pry the back panel off.
    • At this point, the back panel should very easily pop off.
    • Be careful around mechanical components on the edges of the laptop (audio output, USB ports).
  12. Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 12, image 1 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 12, image 2 of 3 Sony Vaio VPCF115FM Back Panel Assembly Replacement: step 12, image 3 of 3
    • Continue popping the back panel off.
    • The back panel should now be off.
Haylie Hotte
638 Reputation
5 Guides authored
2 Comments
The fan ran at high speed and the laptop would randomly shut down. I suspected a cooling problem. Turned out there was a layer of dust caked on the “fan side” of the cooling fins. I removed the fan/heat sink assembly and used a vacuum and an artist’s brush to clean the fins and fan blades. Put a fresh layer of thermal compound on the CPU and GPU heat sinks and reassembled everything. This back panel removal/replacement instruction page was a great help. Everything went back together successfully and, to my amazement, there were no screws left over!
Wil Higdon - Reply
Ganhei um Sony Vaio PCG-81114L usado porem nao tem os parafusos (todos) e nao estou encontrado aqui no Brasil. Tem como ajudar? O procedimento esta 10 e é bem simples. My email: joaocastelor@hotmail.com
joaocastelor - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 1,767
