Sony Vaio VPCW21FX Battery Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Sony Vaio VPCW21FX Battery  Replacement, Battery: step 1, image 1 of 1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Battery  Replacement: step 2, image 1 of 2 Sony Vaio VPCW21FX Battery  Replacement: step 2, image 2 of 2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Battery  Replacement: step 3, image 1 of 2 Sony Vaio VPCW21FX Battery  Replacement: step 3, image 2 of 2
    • Remove the battery from your laptop.
Alexis
192 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 392
