Sony Vaio VPCW21FX Disc Drive Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Sony Vaio VPCW21FX Disc Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Disc Drive Replacement: step 2, image 1 of 2 Sony Vaio VPCW21FX Disc Drive Replacement: step 2, image 2 of 2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Disc Drive Replacement: step 3, image 1 of 2 Sony Vaio VPCW21FX Disc Drive Replacement: step 3, image 2 of 2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Disc Drive Replacement, Disc Drive: step 4, image 1 of 2 Sony Vaio VPCW21FX Disc Drive Replacement, Disc Drive: step 4, image 2 of 2
    • Remove the four 5.2mm screws that are holding in the Disc Drive.
  5. Sony Vaio VPCW21FX Disc Drive Replacement: step 5, image 1 of 3 Sony Vaio VPCW21FX Disc Drive Replacement: step 5, image 2 of 3 Sony Vaio VPCW21FX Disc Drive Replacement: step 5, image 3 of 3
    • Grab the center of the drive and pull away from the computer. It should slide right out.
    • The plastic face plate may come off, this is okay, just push it back into place on the drive
Nicholas Corcoran
401 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 205
