Sony Vaio VPCW21FX Hard Drive Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Sony Vaio VPCW21FX Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Hard Drive Replacement: step 2, image 1 of 2 Sony Vaio VPCW21FX Hard Drive Replacement: step 2, image 2 of 2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Hard Drive Replacement: step 3, image 1 of 2 Sony Vaio VPCW21FX Hard Drive Replacement: step 3, image 2 of 2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: step 4, image 1 of 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: step 4, image 2 of 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: step 4, image 3 of 3
    • Remove the two 4.8mm screws that are holding the bottom right panel cover.
    • Remove the Panel cover by lifting it up.
  5. Sony Vaio VPCW21FX Hard Drive Replacement: step 5, image 1 of 2 Sony Vaio VPCW21FX Hard Drive Replacement: step 5, image 2 of 2
    • Remove the two 4.8mm screws that are holding the hard drive down.
  6. Sony Vaio VPCW21FX Hard Drive Replacement: step 6, image 1 of 3 Sony Vaio VPCW21FX Hard Drive Replacement: step 6, image 2 of 3 Sony Vaio VPCW21FX Hard Drive Replacement: step 6, image 3 of 3
    • Grab the black tab that is attached to the hard drive.
    • Slide hard drive to the left to release it from the computer
    • Pull drive up from there and it will come out.
Nicholas Corcoran
401 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 532
