Sony Vaio VPCW21FX RAM Replacement
  1. Sony Vaio VPCW21FX RAM Replacement, Battery: step 1, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement, Battery: step 1, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement, Battery: step 1, image 3 of 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX RAM Replacement: step 2, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement: step 2, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement: step 2, image 3 of 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX RAM Replacement, RAM: step 3, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement, RAM: step 3, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement, RAM: step 3, image 3 of 3
    • Loosen but do not remove the screw over RAM cover panel.
    • With the screw loosened but not removed, lift up and remove the panel.
  4. Sony Vaio VPCW21FX RAM Replacement: step 4, image 1 of 3 Sony Vaio VPCW21FX RAM Replacement: step 4, image 2 of 3 Sony Vaio VPCW21FX RAM Replacement: step 4, image 3 of 3
    • Locate the mounting bracket holding the RAM Chips in the computer.
    • Pull silver tabs away from the chip.
    • The chip will pop up, this is normal.
    • Don't touch gold pins on RAM chip.
  5. Sony Vaio VPCW21FX RAM Replacement: step 5, image 1 of 2 Sony Vaio VPCW21FX RAM Replacement: step 5, image 2 of 2
    • Slide RAM chip out by holding the sides of the chip and pull away from the computer.
    • Repeat previous steps for second RAM chip.
Nicholas Corcoran
413 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 22
All Time: 3,735
