Sony WH-1000XM4 Microphone Array Replacement
  1. Sony WH-1000XM4 Microphone Array Replacement, Microphone Array: step 1, image 1 of 1
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Microphone Array Replacement: step 2, image 1 of 1
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame. (The right ear cup is pictured, but the process is identical for the left ear cup.)
    • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Microphone Array Replacement: step 3, image 1 of 1
    • Remove the left ear pad. (The right ear cup is pictured, but the process is identical for the left ear cup.)
  4. Sony WH-1000XM4 Microphone Array Replacement: step 4, image 1 of 1
    • Remove the foam liner from the left ear cup's speaker. (The right ear cup is pictured, but the process is identical for the left ear cup.)
  5. Sony WH-1000XM4 Microphone Array Replacement: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the left ear cup cover. (The right ear cup is pictured, but the process is identical for the left ear cup.)
  6. Sony WH-1000XM4 Microphone Array Replacement: step 6, image 1 of 1
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the left ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with many cables.
    • Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
    • Remove the ear cup cover.
  7. Sony WH-1000XM4 Microphone Array Replacement: step 7, image 1 of 1
    • The microphone array uses strong adhesives, you may find it useful to utilize the IFixit iOpener kit's heating pad in aiding its removal.
    • Remove the microphone array ribbon from the ear cup that has just been removed.
    • The microphone array is the copper-colored ribbon along the edge of the ear cup.
7 other people completed this guide.
Spencer Decker
559 Reputation
3 Guides authored
IUPUI, Team 2-1, Harley Fall 2023 Member of IUPUI, Team 2-1, Harley Fall 2023
IUPUI-HARLEY-F23S2G1
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 27
Past 7 Days: 127
Past 30 Days: 532
All Time: 11,003
