Sony WH-1000XM5 Power Board Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
9
Past 7 Days:
62
Past 30 Days:
199
All Time:
2,496
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If you experience your Sony WH-1000XM5 headphones failing to turn on, a blinking charging port light with no power, or limited charging capacity of only 10%, use this guide to replace the power board.
The power board manages the battery, including charging, protecting against overcharging, and incorporating a temperature sensor.
Step 6 requires you to desolder 2 wires connected to the power board. Please wear safety glasses and take caution when handling a hot soldering iron. If you are new to soldering, you can follow the How To Solder and Desolder Connections guide for more in-depth instructions.
Before beginning, make sure to power off your headphones and disconnect from any external power source.
Tools
    1. Sony WH-1000XM5 Power Board Replacement, Earpads: step 1, image 1 of 3 Sony WH-1000XM5 Power Board Replacement, Earpads: step 1, image 2 of 3 Sony WH-1000XM5 Power Board Replacement, Earpads: step 1, image 3 of 3
      Tool used on this step:
      iFixit Opening Tool
      $1.99
      Buy
      • Place the edge of an iFixit opening tool under the earpad cushion.
      • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
      Ask FixBot
    1. Sony WH-1000XM5 Power Board Replacement, Battery: step 2, image 1 of 2 Sony WH-1000XM5 Power Board Replacement, Battery: step 2, image 2 of 2
      Phillips #000 Screwdriver
      $5.49
      Buy
      • Use a Phillips #000 screwdriver to remove the eight screws along the outer inside edge.
      • There is a piece of grey foam you can simply remove to uncover the centre 4 screws.
      • Flip the headphones to the other side and slowly lift up the back plastic cover piece.
      • Gently disconnect the touch sensor ribbon cable by pulling it out evenly from the main board.
      Ask FixBot
    2. Sony WH-1000XM5 Power Board Replacement: step 3, image 1 of 3 Sony WH-1000XM5 Power Board Replacement: step 3, image 2 of 3 Sony WH-1000XM5 Power Board Replacement: step 3, image 3 of 3
      • Peel off the tape covering the battery connector.
      • Pull out the battery and disconnect the battery cable from the motherboard.
      Ask FixBot
    1. Sony WH-1000XM5 Power Board Replacement, Power Board: step 4, image 1 of 1
      • Unplug the main wire and all ribbons from the power board.
      Ask FixBot
    2. Sony WH-1000XM5 Power Board Replacement: step 5, image 1 of 3 Sony WH-1000XM5 Power Board Replacement: step 5, image 2 of 3 Sony WH-1000XM5 Power Board Replacement: step 5, image 3 of 3
      • Use a Phillips #000 screwdriver to remove the two black 1.6mm Phillips screws holding the power board down.
      • Carefully lift the power board from the unit.
      Ask FixBot
    3. Sony WH-1000XM5 Power Board Replacement: step 6, image 1 of 2 Sony WH-1000XM5 Power Board Replacement: step 6, image 2 of 2
      • Before you begin soldering, note the following safety precautions:
      • Always unplug, turn off, and remove power sources before soldering.
      • Do not touch the metal part of the soldering iron! The soldering iron can heat up to over 310°C (600°F).
      • Be extremely careful when you are soldering/desoldering lithium-polymer battery wires! You can easily short the battery with solder or your tools, resulting in battery damage and a fire hazard.
      • Plug in the soldering iron and wait 1-3 minutes for it to heat up.
      • Place the flat side of the soldering iron on the 2 globs of metal for 2-3 seconds as shown.
      • While the globs are still hot, use your tweezers to carefully detach the black and red wires from the power board.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 62
Past 30 Days: 199
All Time: 2,496
