Introduction
Blunt force or exposure to water may lead to the microphone being damaged. Replacing the microphone on the Sony WH-CH520 is a moderately difficult task that requires a basic ability to solder along with a few tools and supplies.
Note: It may be possible to do this repair without extra solder if you reuse the solder connecting the wires and motherboard, but it is always good to have extra.
Hold the headphones in one hand, and with your other hand lightly pinch the earpad cushion.
Remove the three 2.5 mm screws from the headphones using a JIS #00 screwdriver.
Place one end of an opening tool against the edge of the base with the hook-like side pushing up against the covering.
Carefully pull the tool down against the edge to lift the covering.
Move the tool to different spots around the base of the headphones to pry it up until the covering comes off.
