Sony WM-FX123 Belt Replacement
  1. Sony WM-FX123 Belt Replacement, Disassembly: step 1, image 1 of 1
  2. Sony WM-FX123 Belt Replacement, Remove the Belt: step 2, image 1 of 1
    • Carefully remove the belt from around the marked wheels. If it has turned to goo you may need to clean up the residue, which can be done with isopropyl alcohol, cotton buds and/or a toothpick.
  3. Sony WM-FX123 Belt Replacement, Install the new belt: step 3, image 1 of 1
    • Install the new belt around the wheels as pictured. Try to avoid twisting the belt as you install it or you may have issues later.
  4. Sony WM-FX123 Belt Replacement, Reassembly: step 4, image 1 of 2 Sony WM-FX123 Belt Replacement, Reassembly: step 4, image 2 of 2
    • Reinstall the rear cover by following steps 3-1 of the disassembly guide.
    • Once you have reassembled the unit, pop a cassette and some batteries in and give it a test!
To reassemble your device, follow steps 3-1 of the disassembly guide.
psander
218 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 58
All Time: 785
