Sony Walkman NWZ-S764 Bluetooth module Replacement
  1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: step 1, image 1 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: step 1, image 2 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: step 1, image 3 of 3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Bluetooth module Replacement: step 2, image 1 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: step 2, image 2 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: step 2, image 3 of 3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Bluetooth module Replacement: step 3, image 1 of 2 Sony Walkman NWZ-S764 Bluetooth module Replacement: step 3, image 2 of 2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Bluetooth module Replacement: step 4, image 1 of 2 Sony Walkman NWZ-S764 Bluetooth module Replacement: step 4, image 2 of 2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: step 5, image 1 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: step 5, image 2 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: step 5, image 3 of 3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Bluetooth module Replacement: step 6, image 1 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: step 6, image 2 of 3 Sony Walkman NWZ-S764 Bluetooth module Replacement: step 6, image 3 of 3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
John Ferguson
657 Reputation
5 Guides authored
USF Tampa, Team 4-2, Brown Winter 2015 Member of USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 661
