Sony Walkman NWZ-S764 Frame Replacement
John Ferguson
John Ferguson and 4 other contributors
Last updated on October 17, 2016
No estimate
Moderate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
Prerequisite Only
Tools
  1. Sony Walkman NWZ-S764 Frame Replacement, Removing the back cover: step 1, image 1 of 3 Sony Walkman NWZ-S764 Frame Replacement, Removing the back cover: step 1, image 2 of 3 Sony Walkman NWZ-S764 Frame Replacement, Removing the back cover: step 1, image 3 of 3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Frame Replacement: step 2, image 1 of 3 Sony Walkman NWZ-S764 Frame Replacement: step 2, image 2 of 3 Sony Walkman NWZ-S764 Frame Replacement: step 2, image 3 of 3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Frame Replacement: step 3, image 1 of 2 Sony Walkman NWZ-S764 Frame Replacement: step 3, image 2 of 2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Frame Replacement: step 4, image 1 of 2 Sony Walkman NWZ-S764 Frame Replacement: step 4, image 2 of 2
    • Carefully pull the top piece away from the device.
John Ferguson
657 Reputation
5 Guides authored
USF Tampa, Team 4-2, Brown Winter 2015 Member of USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 48
