Sony Walkman WM-AF48 Power Switch Replacement
  1. Sony Walkman WM-AF48 Power Switch Replacement, Getting started: step 1, image 1 of 1
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: step 2, image 1 of 3 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: step 2, image 2 of 3 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: step 2, image 3 of 3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: step 3, image 1 of 2 Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: step 3, image 2 of 2
    • Gently pull the ribbon from the jack above the film revolver, near the edge.
    • Lift the motherboard from the outer shell.
    • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
  4. Sony Walkman WM-AF48 Power Switch Replacement, Remove the power switch: step 4, image 1 of 1
    • Identify the six points where the power switch is soldered to the motherboard.
    • Using a soldering iron, remove the switch by de-soldering these points which hold it in place.
Wilson Riforgiat
924 Reputation
4 Guides authored
One Comment
Hi,
Where would you find a Vintage Sports Sony Walkman power switch ? Battery light is on one function and then turns off on the other. Other than this, the unit is in EXCELLENT Condition. THANKS for any insight and for helping us :)
Pamela Osborne - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,123
