Sony XAV-AX100 USB Cable Replacement
  1. Sony XAV-AX100 USB Cable Replacement, USB Cable: step 1, image 1 of 3 Sony XAV-AX100 USB Cable Replacement, USB Cable: step 1, image 2 of 3 Sony XAV-AX100 USB Cable Replacement, USB Cable: step 1, image 3 of 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 USB Cable Replacement: step 2, image 1 of 2 Sony XAV-AX100 USB Cable Replacement: step 2, image 2 of 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 USB Cable Replacement: step 3, image 1 of 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 USB Cable Replacement: step 4, image 1 of 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 USB Cable Replacement: step 5, image 1 of 3 Sony XAV-AX100 USB Cable Replacement: step 5, image 2 of 3 Sony XAV-AX100 USB Cable Replacement: step 5, image 3 of 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
Abdulaziz Redha
741 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Cagle Spring 2018 Member of USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Members
5 Guides authored
3 Guide Comments
Where i can get replacement lead?
mudylla - Reply
where can i get a replacement lead for this please
Andy 777 - Reply
im in the UK
Andy 777 - Reply
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 47
All Time: 5,245
