Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: step 1, image 1 of 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: step 1, image 2 of 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: step 2, image 1 of 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: step 2, image 2 of 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: step 2, image 3 of 3
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: step 3, image 1 of 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: step 3, image 2 of 3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: step 3, image 3 of 3
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
2 other people completed this guide.
Martin Luna
1,873 Reputation
5 Guides authored
USF Tampa, Team 15-6, Remmell Fall 2014 Member of USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,972
