Sony XPERIA Tablet Z Volume Button Replacement
  1. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: step 1, image 1 of 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: step 1, image 2 of 3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
    • Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
  2. Sony XPERIA Tablet Z Volume Button Replacement, Locate the Volume module: step 2, image 1 of 1
    • Locate the volume module.
    • Remove both screws using the Philips screwdriver.
  3. Sony XPERIA Tablet Z Volume Button Replacement, Lift out of Place: step 3, image 1 of 1
    • Once both screws are removed grab the tweezers.
    • Then lift up on the module.
  4. Sony XPERIA Tablet Z Volume Button Replacement, Removing the Electrical tape: step 4, image 1 of 1
    • Find the electrical tape connecting the module to the motherboard
    • Carefully pull out the electrical tape horizontally and remove the volume module from the device.
Martin Luna
1,873 Reputation
5 Guides authored
USF Tampa, Team 15-6, Remmell Fall 2014 Member of USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 2,417
