Sony Xperia E C1505 C1504 LCD Display Replacement
Video Overview
  1. Sony Xperia E C1505 C1504 LCD Display Replacement, LCD Display: step 1, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement, LCD Display: step 1, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement, LCD Display: step 1, image 3 of 3
    • Switch-off the phone and remove the battery.
  2. Sony Xperia E C1505 C1504 LCD Display Replacement: step 2, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 2, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 2, image 3 of 3
    • The small bottom bezel is held by 2x locking clips.
    • Preferably use plastic tools for disassembling.
  3. Sony Xperia E C1505 C1504 LCD Display Replacement: step 3, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 3, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 3, image 3 of 3
    • There are 4x silver screws and 3x black screws.
    • The rear cover is held by 5x locking clips.
    • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  4. Sony Xperia E C1505 C1504 LCD Display Replacement: step 4, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 4, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 4, image 3 of 3
    • Remove the back cover.
    • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
  5. Sony Xperia E C1505 C1504 LCD Display Replacement: step 5, image 1 of 2 Sony Xperia E C1505 C1504 LCD Display Replacement: step 5, image 2 of 2
    • Carefully remove the main board.
  6. Sony Xperia E C1505 C1504 LCD Display Replacement: step 6, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 6, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 6, image 3 of 3
    • Disconnect the other side of the flex cable and remove the Home Buttons board.
    • Unstick the camera button.
  7. Sony Xperia E C1505 C1504 LCD Display Replacement: step 7, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 7, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 7, image 3 of 3
    • The touch screen is stuck to the frame with double side adhesive tape.
    • By using plastic tools gently start separating.
    • At the bottom is glued on firmly because the bonded surface is larger.
    • Use a hot air to make separating more easy and safety.
  8. Sony Xperia E C1505 C1504 LCD Display Replacement: step 8, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 8, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 8, image 3 of 3
    • With a plastic tool, carefully separate the LCD display from the touch screen.
    • Clear the LCD Display from the old adhesive tape.
  9. Sony Xperia E C1505 C1504 LCD Display Replacement: step 9, image 1 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 9, image 2 of 3 Sony Xperia E C1505 C1504 LCD Display Replacement: step 9, image 3 of 3
    • Install the new LCD into the frame and put adhesive tape. Be careful not to cover the holes (for the speaker, menu buttons etc.).
    • Install the Touchscreen.
  10. Sony Xperia E C1505 C1504 LCD Display Replacement: step 10, image 1 of 1
2 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 11,738
