Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement
Video Overview
  1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: step 1, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: step 1, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: step 1, image 3 of 3
    • Switch-off the phone.
    • Remove the battery.
  2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 2, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 2, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 2, image 3 of 3
    • The small bottom bezel is held by 2x locking clips.
    • Preferably use plastic tools for disassembling.
  3. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 3, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 3, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 3, image 3 of 3
    • There are 4x silver screws and 3x black screws.
    • The rear cover is held by 5x locking clips.
    • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  4. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 4, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 4, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 4, image 3 of 3
    • Remove the back cover.
    • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
  5. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 5, image 1 of 2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 5, image 2 of 2
    • Carefully remove the main board.
  6. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 6, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 6, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 6, image 3 of 3
    • Disconnect the other side of the flex cable and remove the Home Buttons board.
    • Unstick the camera button.
  7. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 7, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 7, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 7, image 3 of 3
    • The touch screen is stuck to the frame with double side adhesive tape.
    • By using plastic tools gently start separating.
    • At the bottom is glued on firmly because the bonded surface is larger.
    • Use a hot air to make separating more easy and safety.
  8. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 8, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 8, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 8, image 3 of 3
    • With a plastic tool, carefully separate the LCD display from the touch screen.
    • Clear the touchscreen from the old adhesive tape.
  9. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 9, image 1 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 9, image 2 of 3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 9, image 3 of 3
    • Install the new LCD into the frame and put adhesive tape.
    • Be careful not to cover the holes (for the speaker, menu buttons etc.). Install the Touchscreen.
  10. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: step 10, image 1 of 1
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
2 Comments
Sir
Please help
Mera phone SONY C1504
Display connector kharab ho gya
Hai new mil sakta hai
Please help
Yogendra Singh - Reply
Jo PCB main hota hai
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,993
