Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement
Video Overview
  1. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: step 1, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: step 1, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: step 1, image 3 of 3
    • Turn off the phone, remove the battery, SIM card and micro SD card.
    • The screws are Torx T4. One of them, near the microSD card reader is different.
  2. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 2, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 2, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 2, image 3 of 3
    • Use a plastic tool to remove the middle frame.
    • Loudspeaker
  3. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 3, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 3, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 3, image 3 of 3
    • Touch screen flex cable. Disconnect it.
    • LCD Display flex cable. Open the connector.
    • The logic board is held to the display frame by several plastic locking clips. Use a plastic tool to remove it.
  4. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 4, image 1 of 1
    • Earpiece.
  5. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 5, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 5, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 5, image 3 of 3
    • Release the LCD display from the main board.
  6. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 6, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 6, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 6, image 3 of 3
    • If the glass is broken, put some scotch tape to prevent it from breaking to pieces.
    • Use a hot air to soften the adhesive tape.
    • You can use a hairdryer.
    • Start with separating at the middle, where the contact area is smaller.
  7. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 7, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 7, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 7, image 3 of 3
    • Use a plastic tool for separating the glass from the frame.
  8. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 8, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 8, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 8, image 3 of 3
    • Clean the frame.
    • Put adhesive tape if the new spare part doesn't have any.
    • Be careful, don't cover the holes for the microphone, proximity sensor, etc.
    • Install the new Digitizer.
  9. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 9, image 1 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 9, image 2 of 3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 9, image 3 of 3
    • Use again hot air and some pressure to stick the glass better.
    • Start wit reassembling.
  10. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: step 10, image 1 of 1
    • That's all.
    • Did you do it successfully?
2 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
2 Comments
Sony xperia d2005 touch
rhaman516 - Reply
Hi I have a problem with wifi it's a hardware issue as I dropped it yesterday since from then the issue started please help me to fix it
Om Prakash - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 12,962
