Sony Xperia E4 Logic Board Replacement
Video Overview
  1. Sony Xperia E4 Logic Board Replacement, Battery Cover: step 1, image 1 of 3 Sony Xperia E4 Logic Board Replacement, Battery Cover: step 1, image 2 of 3 Sony Xperia E4 Logic Board Replacement, Battery Cover: step 1, image 3 of 3
    • Remove the back cover and any installed SIM and memory cards.
    • There are 8x black screws Torx T4. Remove them.
  2. Sony Xperia E4 Logic Board Replacement: step 2, image 1 of 3 Sony Xperia E4 Logic Board Replacement: step 2, image 2 of 3 Sony Xperia E4 Logic Board Replacement: step 2, image 3 of 3
    • Remove the small black rubber at the lower left corner.
    • Under it is the battery flex cable, disconnect it.
  3. Sony Xperia E4 Logic Board Replacement: step 3, image 1 of 3 Sony Xperia E4 Logic Board Replacement: step 3, image 2 of 3 Sony Xperia E4 Logic Board Replacement: step 3, image 3 of 3
    • Use a plastic tool to separate the middle frame.
    • The battery is glued to the middle frame with an adhesive tape.
    • Loudspeaker
  4. Sony Xperia E4 Logic Board Replacement, Logic Board: step 4, image 1 of 3 Sony Xperia E4 Logic Board Replacement, Logic Board: step 4, image 2 of 3 Sony Xperia E4 Logic Board Replacement, Logic Board: step 4, image 3 of 3
    • Disconnect the touch screen flex cable.
    • Under it is the LCD flex cable. Disconnect it also.
  5. Sony Xperia E4 Logic Board Replacement: step 5, image 1 of 3 Sony Xperia E4 Logic Board Replacement: step 5, image 2 of 3 Sony Xperia E4 Logic Board Replacement: step 5, image 3 of 3
    • Remove the logic board.
    • Be careful for the flex cables.
7 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
One Comment
Anh ơi điện thoại của em ko vào đc mà hình chính nó hiện logo sony xong ko vào đc màn hình chính
Anh Nguyen - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 2,546
