Sony Xperia E4 Touch Screen Glass / LCD Display Replacement
Video Overview
  1. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: step 1, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: step 1, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: step 1, image 3 of 3
    • Remove the back cover and any installed SIM and memory cards.
    • There are 8x black screws Torx T4. Remove them.
  2. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 2, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 2, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 2, image 3 of 3
    • Remove the small black rubber at the lower left corner.
    • Under it is the battery flex cable, disconnect it.
  3. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 3, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 3, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 3, image 3 of 3
    • Use a plastic tool to separate the middle frame.
    • The battery is glued to the middle frame with an adhesive tape.
    • Loudspeaker
  4. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: step 4, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: step 4, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: step 4, image 3 of 3
    • Disconnect the touch screen flex cable.
    • Under it is the LCD flex cable. Disconnect it also.
  5. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 5, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 5, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 5, image 3 of 3
    • Remove the logic board.
    • Be careful for the flex cables.
  6. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: step 6, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: step 6, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: step 6, image 3 of 3
    • Cover the glass with a scotch tape.
    • Warm the glass for about minute.
    • With a cutter lift a little the glase to make a room for the plastic tool.
  7. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 7, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 7, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 7, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Carefully put the plastic tool between the glass and the LCD.
    • The tool must be thin, you can use also a plastic card.
    • Periodically warm the glass.
    • Remove the display frame.
  8. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 8, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 8, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 8, image 3 of 3
    • Use only plastic tools and don't force the LCD.
  9. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 9, image 1 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 9, image 2 of 3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 9, image 3 of 3
    • Install adhesive tape.
    • It's easier if you order your touch screen together with adhesive sticker.
    • Start with the reassembling.
  10. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: step 10, image 1 of 1
    • That's all.
12 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
4 Comments
Grazie! È stato davvero utilissimo. :)
Andrea DePa - Reply
Doesn't the original glass and digitalizer come out with its biadesive?
marco bigoni - Reply
First Timer here:
I've followed this and replaced the cracked screen (the clear bit).
But it still looks cracked; could it be that I have a cracked LCD thingy as well? (is that the black bit?).
If so what's the part number for that?
MartynJ - Reply
Why don't you just buy the screen which has the lcd and digitiser already assembled? That will save you a lot of hassle for only a few £'s more :)
Clems - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 20,286
