Sony Xperia L2 LTE Charging Port Replacement
  1. Sony Xperia L2 LTE Charging Port Replacement, Battery: step 1, image 1 of 2 Sony Xperia L2 LTE Charging Port Replacement, Battery: step 1, image 2 of 2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Charging Port Replacement: step 2, image 1 of 3 Sony Xperia L2 LTE Charging Port Replacement: step 2, image 2 of 3 Sony Xperia L2 LTE Charging Port Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Charging Port Replacement: step 3, image 1 of 1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Charging Port Replacement: step 4, image 1 of 2 Sony Xperia L2 LTE Charging Port Replacement: step 4, image 2 of 2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Charging Port Replacement, Charging Port: step 5, image 1 of 2 Sony Xperia L2 LTE Charging Port Replacement, Charging Port: step 5, image 2 of 2
    • Use a plastic opening tool to lift the charging port circuit board.
  6. Sony Xperia L2 LTE Charging Port Replacement: step 6, image 1 of 1
    • Unhook the antenna from circuit board using a plastic opening tool and remove the charging port circuit board from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 650
