Introduction
If your camera broke or doesn't work you may need to replace it from the board. This will show you how to do it.
Place phone down with screen side down and camera side facing up as shown.
Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
Tool used on this step:Tweezers$4.99
Using the tweezers remove the camera from the power source.
Pick up board and remove camera module. The module should seem to just pop out.
2 other people completed this guide.
