Sony Xperia Sola Speaker Replacement
  1. Sony Xperia Sola Speaker Replacement, Speaker: step 1, image 1 of 1
    • Lay the phone as shown and put the camera facing up.
  2. Sony Xperia Sola Speaker Replacement: step 2, image 1 of 2 Sony Xperia Sola Speaker Replacement: step 2, image 2 of 2
    • Push the back cover as shown, then lift the cover off.
  3. Sony Xperia Sola Speaker Replacement: step 3, image 1 of 3 Sony Xperia Sola Speaker Replacement: step 3, image 2 of 3 Sony Xperia Sola Speaker Replacement: step 3, image 3 of 3
    • Remove the five screws as shown on the phone by using 26 Bit Kit.
    • Use a T6 screwdriver bit to remove top two screws.
    • Use a J000 screwdriver bit to remove the bottom two screws.
    • Use a T3 screwdriver bit to remove the middle screw (close to camera).
  4. Sony Xperia Sola Speaker Replacement: step 4, image 1 of 2 Sony Xperia Sola Speaker Replacement: step 4, image 2 of 2
    • Use plastic opening tool to remove the bottom white cover as shown.
  5. Sony Xperia Sola Speaker Replacement: step 5, image 1 of 2 Sony Xperia Sola Speaker Replacement: step 5, image 2 of 2
    • There are two additional screws under the bottom white cover as shown.
    • Use T3 drivers to remove two additional screws as shown.
  6. Sony Xperia Sola Speaker Replacement: step 6, image 1 of 3 Sony Xperia Sola Speaker Replacement: step 6, image 2 of 3 Sony Xperia Sola Speaker Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Using plastic opening tool, lift to remove the small black cover on the bottom left of phone as shown.
    • Then, using tweezers to lift the connector straight up to disconnect the battery's circuit as shown.
  7. Sony Xperia Sola Speaker Replacement: step 7, image 1 of 3 Sony Xperia Sola Speaker Replacement: step 7, image 2 of 3 Sony Xperia Sola Speaker Replacement: step 7, image 3 of 3
    • Turn the phone onto its side and insert a flat object and gently remove cover, using plastic opening tool as shown.
  8. Sony Xperia Sola Speaker Replacement: step 8, image 1 of 3 Sony Xperia Sola Speaker Replacement: step 8, image 2 of 3 Sony Xperia Sola Speaker Replacement: step 8, image 3 of 3
    • Flip over the black back cover and locate the speaker phone at the bottom, then use the tweezers to remove the speaker. It is glued to the back cover so a little force will be needed.
3 other people completed this guide.
Bo Wu
292 Reputation
2 Guides authored
USF Tampa, Team S5-G3, Lacy Spring 2017 Member of USF Tampa, Team S5-G3, Lacy Spring 2017
USFT-LACY-S17S5G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 354
