Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement
  1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Rear Case: step 1, image 1 of 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 2, image 1 of 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing the internal cover: step 3, image 1 of 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 4, image 1 of 2 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 4, image 2 of 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing Chip: step 5, image 1 of 1
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  6. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 6, image 1 of 1
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  7. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Remove back facing camera: step 7, image 1 of 1
    • Then using the tweezer, carefully remove the back facing camera component.
  8. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing the Front Camera: step 8, image 1 of 1
    • Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
  9. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing chip: step 9, image 1 of 1
    • Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
  10. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Remove audio jack: step 10, image 1 of 1
    Tool used on this step:
    Buy
    • Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
  11. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Motherboard: step 11, image 1 of 2 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Motherboard: step 11, image 2 of 2
    Buy
    • Using tweezers, locate the battery connector and carefully pull up to disconnect it.
  12. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 12, image 1 of 2 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 12, image 2 of 2
    • Carefully remove the button circuit connector by using tweezers and gently pulling up.
  13. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 13, image 1 of 2 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 13, image 2 of 2
    • Carefully remove the silver plug by using the tweezers to lift straight up.
  14. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 14, image 1 of 2 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 14, image 2 of 2
    • Carefully remove the SIM card connector using tweezers by gently pulling it straight up.
  15. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 15, image 1 of 2 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: step 15, image 2 of 2
    • Using tweezers, carefully remove the motherboard by pulling it up and out of the backing.
  16. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Dual SIM Slot: step 16, image 1 of 1
    Buy
    • Using the Tweezers, carefully pry the the dual SIM slot off the sticky substance used to hold it down.
2 other people completed this guide.
Austin Kreutzjans
157 Reputation
1 Guide authored
IUPUI, Team S1-G3, Harley Spring 2017 Member of IUPUI, Team S1-G3, Harley Spring 2017
IUPUI-HARLEY-S17S1G3
4 Members
3 Guides authored
One Comment
Clear video and tutorial!
But why make the process too long where in fact you can do it fast and simple by directly pulling out the dual sim card reader/slot off the board right after removing the mid-frame cover (after Step 4), and thereafter put in the replacement part?
The 16 steps can be done in just 5 or 6 steps.
Might as well re-title this to: Partial Disassembly of Xperia T2 Ulta Dual.
profeduards - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 2,950
