Sony Xperia TL Back Panel Replacement
  1. Sony Xperia TL Back Panel Replacement, Remove Top Plastic Section: step 1, image 1 of 3 Sony Xperia TL Back Panel Replacement, Remove Top Plastic Section: step 1, image 2 of 3 Sony Xperia TL Back Panel Replacement, Remove Top Plastic Section: step 1, image 3 of 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Back Panel Replacement, Remove Bottom Plastic Section: step 2, image 1 of 2 Sony Xperia TL Back Panel Replacement, Remove Bottom Plastic Section: step 2, image 2 of 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Back Panel Replacement, Unscrewing the Back Off: step 3, image 1 of 3 Sony Xperia TL Back Panel Replacement, Unscrewing the Back Off: step 3, image 2 of 3 Sony Xperia TL Back Panel Replacement, Unscrewing the Back Off: step 3, image 3 of 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
2 other people completed this guide.
Nathan Laneau
435 Reputation
2 Guides authored
USF Tampa, Team 4-4, Brown Fall 2014 Member of USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 595
