Introduction
If your phone's camera is not working properly and need replacement, follow these steps to guide you through the replacement process.
Set the phone screen down on a clean flat, surface.
Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
Use the tweezers to detach the flex cable to remove the camera.
