Sony Xperia U Speaker Replacement
  1. Sony Xperia U Speaker Replacement, Battery: step 1, image 1 of 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Speaker Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Speaker Replacement, Headphone Jack: step 3, image 1 of 1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Speaker Replacement: step 4, image 1 of 1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Speaker Replacement: step 5, image 1 of 1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Speaker Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
  7. Sony Xperia U Speaker Replacement, Speaker: step 7, image 1 of 1
    Buy
    • Using the tweezers, remove the loudspeaker module by firmly grasping it on one side, then slowly and carefully pulling the module in an upward direction.
3 other people completed this guide.
Bader
545 Reputation
4 Guides authored
USF Tampa, Team 7-2, Leahy Fall 2014 Member of USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 7
All Time: 932
