Sony Xperia XA Back Camera Replacement
  1. Sony Xperia XA Back Camera Replacement, Back Cover: step 1, image 1 of 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Back Camera Replacement: step 2, image 1 of 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Back Camera Replacement: step 3, image 1 of 3 Sony Xperia XA Back Camera Replacement: step 3, image 2 of 3 Sony Xperia XA Back Camera Replacement: step 3, image 3 of 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Back Camera Replacement: step 4, image 1 of 3 Sony Xperia XA Back Camera Replacement: step 4, image 2 of 3 Sony Xperia XA Back Camera Replacement: step 4, image 3 of 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Back Camera Replacement: step 5, image 1 of 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Back Camera Replacement: step 6, image 1 of 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Back Camera Replacement, Motherboard: step 7, image 1 of 2 Sony Xperia XA Back Camera Replacement, Motherboard: step 7, image 2 of 2
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Back Camera Replacement: step 8, image 1 of 2 Sony Xperia XA Back Camera Replacement: step 8, image 2 of 2
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Back Camera Replacement: step 9, image 1 of 3 Sony Xperia XA Back Camera Replacement: step 9, image 2 of 3 Sony Xperia XA Back Camera Replacement: step 9, image 3 of 3
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Back Camera Replacement: step 10, image 1 of 2 Sony Xperia XA Back Camera Replacement: step 10, image 2 of 2
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Back Camera Replacement: step 11, image 1 of 2 Sony Xperia XA Back Camera Replacement: step 11, image 2 of 2
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Back Camera Replacement: step 12, image 1 of 3 Sony Xperia XA Back Camera Replacement: step 12, image 2 of 3 Sony Xperia XA Back Camera Replacement: step 12, image 3 of 3
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Back Camera Replacement: step 13, image 1 of 3 Sony Xperia XA Back Camera Replacement: step 13, image 2 of 3 Sony Xperia XA Back Camera Replacement: step 13, image 3 of 3
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Back Camera Replacement: step 14, image 1 of 2 Sony Xperia XA Back Camera Replacement: step 14, image 2 of 2
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Back Camera Replacement: step 15, image 1 of 3 Sony Xperia XA Back Camera Replacement: step 15, image 2 of 3 Sony Xperia XA Back Camera Replacement: step 15, image 3 of 3
    Tool used on this step:
    Buy
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Back Camera Replacement: step 16, image 1 of 2 Sony Xperia XA Back Camera Replacement: step 16, image 2 of 2
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Back Camera Replacement: step 17, image 1 of 3 Sony Xperia XA Back Camera Replacement: step 17, image 2 of 3 Sony Xperia XA Back Camera Replacement: step 17, image 3 of 3
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
  18. Sony Xperia XA Back Camera Replacement, Back Camera: step 18, image 1 of 2 Sony Xperia XA Back Camera Replacement, Back Camera: step 18, image 2 of 2
    • Use the nylon spudger to pry up the black camera connector from the motherboard.
    • The connector is attached with adhesive.
  19. Sony Xperia XA Back Camera Replacement: step 19, image 1 of 1
    • Use your fingers to gently pull the camera off the motherboard.
Theresa Wilcoski
328 Reputation
2 Guides authored
Cal Poly, Team S17-G2, Livingston Spring 2018 Member of Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 967
