Sony Xperia XA Back Cover Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Sony Xperia XA Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Back Cover Replacement: step 2, image 1 of 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Back Cover Replacement: step 3, image 1 of 3 Sony Xperia XA Back Cover Replacement: step 3, image 2 of 3 Sony Xperia XA Back Cover Replacement: step 3, image 3 of 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Back Cover Replacement: step 4, image 1 of 3 Sony Xperia XA Back Cover Replacement: step 4, image 2 of 3 Sony Xperia XA Back Cover Replacement: step 4, image 3 of 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Back Cover Replacement: step 5, image 1 of 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Back Cover Replacement: step 6, image 1 of 1
    • Peel back the RAF antenna.
Anthony Hernandez
733 Reputation
3 Guides authored
Cal Poly, Team S17-G2, Livingston Spring 2018 Member of Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 142
