Sony Xperia XA1 Audio Jack Replacement
  1. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: step 1, image 1 of 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: step 1, image 2 of 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: step 1, image 3 of 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: step 2, image 1 of 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: step 2, image 2 of 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: step 2, image 3 of 3
    • Use a Phillips #000 Screwdriver to remove the three 3 mm screws from the top bracket.
  3. Sony Xperia XA1 Audio Jack Replacement: step 3, image 1 of 3 Sony Xperia XA1 Audio Jack Replacement: step 3, image 2 of 3 Sony Xperia XA1 Audio Jack Replacement: step 3, image 3 of 3
    • Use a spudger to gently pry the three tabs at the top of the phone and release the camera cover.
    • Gently lift the cover.
  4. Sony Xperia XA1 Audio Jack Replacement: step 4, image 1 of 3 Sony Xperia XA1 Audio Jack Replacement: step 4, image 2 of 3 Sony Xperia XA1 Audio Jack Replacement: step 4, image 3 of 3
    • Use the Phillips #000 Screwdriver to remove the 3 mm screw to the left of the audio jack component.
    • Use an opening tool to lift the audio jack connector.
    • Pinch the connector and remove the audio jack.
Lindsey Taysom
205 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 155
