Sony Xperia XA1 Screen Replacement
  1. Sony Xperia XA1 Screen Replacement, Phone Back Cover: step 1, image 1 of 3 Sony Xperia XA1 Screen Replacement, Phone Back Cover: step 1, image 2 of 3 Sony Xperia XA1 Screen Replacement, Phone Back Cover: step 1, image 3 of 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Screen Replacement, Speaker: step 2, image 1 of 3 Sony Xperia XA1 Screen Replacement, Speaker: step 2, image 2 of 3 Sony Xperia XA1 Screen Replacement, Speaker: step 2, image 3 of 3
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
  3. Sony Xperia XA1 Screen Replacement: step 3, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 3, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 3, image 3 of 3
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
  4. Sony Xperia XA1 Screen Replacement: step 4, image 1 of 2 Sony Xperia XA1 Screen Replacement: step 4, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
  5. Sony Xperia XA1 Screen Replacement: step 5, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 5, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 5, image 3 of 3
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
  6. Sony Xperia XA1 Screen Replacement, USB-C Module: step 6, image 1 of 3 Sony Xperia XA1 Screen Replacement, USB-C Module: step 6, image 2 of 3 Sony Xperia XA1 Screen Replacement, USB-C Module: step 6, image 3 of 3
    • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
    • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
  7. Sony Xperia XA1 Screen Replacement: step 7, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 7, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 7, image 3 of 3
    • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
    • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
  8. Sony Xperia XA1 Screen Replacement, Screen: step 8, image 1 of 3 Sony Xperia XA1 Screen Replacement, Screen: step 8, image 2 of 3 Sony Xperia XA1 Screen Replacement, Screen: step 8, image 3 of 3
    • Using a spudger, carefully remove the thin copper piece attached to the motherboard.
    • This part is very easy to damage and can not be reused if damaged too much.
  9. Sony Xperia XA1 Screen Replacement: step 9, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 9, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 9, image 3 of 3
    • Carefully remove the front-facing camera with a spudger or your fingers.
  10. Sony Xperia XA1 Screen Replacement: step 10, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 10, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 10, image 3 of 3
    • Remove the single 3mm screw holding the audio jack using a Phillips #000 bit.
    • Using an iFixit Opening Tool, disconnect the audio jack from the motherboard.
    • Use a prying tool, such as a spudger, to remove the audio jack.
  11. Sony Xperia XA1 Screen Replacement: step 11, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 11, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 11, image 3 of 3
    • Disconnect the camera using an iFixit opening tool and remove it with your fingers.
  12. Sony Xperia XA1 Screen Replacement: step 12, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 12, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 12, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the two antennas from the motherboard using an iFixit opening tool or pair of tweezers.
  13. Sony Xperia XA1 Screen Replacement: step 13, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 13, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 13, image 3 of 3
    • Remove the SIM tray using your fingernail.
    • Using a spudger, remove the two connector tabs attached to the motherboard
  14. Sony Xperia XA1 Screen Replacement: step 14, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 14, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 14, image 3 of 3
    • Remove the single 3mm screw from the motherboard using a Phillips #000 bit.
    • Use a spudger to gently pry the motherboard free.
  15. Sony Xperia XA1 Screen Replacement: step 15, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 15, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 15, image 3 of 3
    • Peel the plastic battery tabs free.
  16. Sony Xperia XA1 Screen Replacement: step 16, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 16, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 16, image 3 of 3
    • Using a pair of angled tweezers, carefully remove the earpiece.
    • The ear piece is attached using a sticky adhesive
  17. Sony Xperia XA1 Screen Replacement: step 17, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 17, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 17, image 3 of 3
    • Using a pair of angled tweezers, carefully remove the small metal bracket from the top left side of the phone.
  18. Sony Xperia XA1 Screen Replacement: step 18, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 18, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 18, image 3 of 3
    • Remove the four 3mm silver screws located on the left side of the case using a Phillips #000 bit.
    • Once the screws are removed, unfold the side piece.
  19. Sony Xperia XA1 Screen Replacement: step 19, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 19, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 19, image 3 of 3
    • Using a pair of angled tweezers, remove the power and volume buttons.
  20. Sony Xperia XA1 Screen Replacement: step 20, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 20, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 20, image 3 of 3
    • Carefully remove the antennas.
    • Use a pair of tweezers if needed.
  21. Sony Xperia XA1 Screen Replacement: step 21, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 21, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 21, image 3 of 3
    • Remove the four 3mm silver screws from the right side of the phone using a Phillips #000 bit.
    • Once unfolded, peel the side piece from the phone, separating the glue that holds the two pieces together.
  22. Sony Xperia XA1 Screen Replacement: step 22, image 1 of 3 Sony Xperia XA1 Screen Replacement: step 22, image 2 of 3 Sony Xperia XA1 Screen Replacement: step 22, image 3 of 3
    • Remove the other side in the same manner.
    • All removeable components should be free, ready to be installed into your replacement screen.
Hunter
349 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 264
