Sony Xperia XA1 USB-C Module Replacement
  1. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: step 1, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: step 1, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: step 1, image 3 of 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 USB-C Module Replacement, Speaker: step 2, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: step 2, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement, Speaker: step 2, image 3 of 3
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
  3. Sony Xperia XA1 USB-C Module Replacement: step 3, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement: step 3, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement: step 3, image 3 of 3
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
  4. Sony Xperia XA1 USB-C Module Replacement: step 4, image 1 of 2 Sony Xperia XA1 USB-C Module Replacement: step 4, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
  5. Sony Xperia XA1 USB-C Module Replacement: step 5, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement: step 5, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement: step 5, image 3 of 3
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
  6. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: step 6, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: step 6, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement, USB-C Module: step 6, image 3 of 3
    • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
    • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
  7. Sony Xperia XA1 USB-C Module Replacement: step 7, image 1 of 3 Sony Xperia XA1 USB-C Module Replacement: step 7, image 2 of 3 Sony Xperia XA1 USB-C Module Replacement: step 7, image 3 of 3
    • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
    • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
sebastianh034
253 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 640
