Sony Xperia Z Display Assembly Replacement
Video Overview
  1. Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: step 1, image 1 of 3 Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: step 1, image 2 of 3 Sony Xperia Z Display Assembly Replacement, Touch Screen Glass Digitizer & LCD Display: step 1, image 3 of 3
    • Warm the Battery cover before disassemble it.
  2. Sony Xperia Z Display Assembly Replacement: step 2, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 2, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 2, image 3 of 3
    • 'Carefully' warm the battery too
  3. Sony Xperia Z Display Assembly Replacement: step 3, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 3, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 3, image 3 of 3
    • Unscrew 4x screws and disconnect 3x flex cables in case to free the mother board.
  4. Sony Xperia Z Display Assembly Replacement: step 4, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 4, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 4, image 3 of 3
    • This are: main Camera, front Camera and antenna wire Flex cable.
    • Now we can remove the Motherboard.
  5. Sony Xperia Z Display Assembly Replacement: step 5, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 5, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 5, image 3 of 3
    • The Headphone connector and the Ringer / Cover / Signal Antenna module.
  6. Sony Xperia Z Display Assembly Replacement: step 6, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 6, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 6, image 3 of 3
    • Disconnect the LCD light flex cable by lifting up the black plastic and removing the flex cable from the right side and we are ready to go.
  7. Sony Xperia Z Display Assembly Replacement: step 7, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 7, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 7, image 3 of 3
    • Warm the Touch screen before you start to disassemble it.
  8. Sony Xperia Z Display Assembly Replacement: step 8, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 8, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 8, image 3 of 3
    • Let's assemble the new spare part.
  9. Sony Xperia Z Display Assembly Replacement: step 9, image 1 of 3 Sony Xperia Z Display Assembly Replacement: step 9, image 2 of 3 Sony Xperia Z Display Assembly Replacement: step 9, image 3 of 3
76 other people completed this guide.
ZFix
196,412 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
333 Members
1,473 Guides authored
54 Guide Comments
Same procedure with Sony Xperia Z2?
Fredrik - Reply Share
How do you warm it? With what and what temperature ?
Jeroen - Reply Share
with a hairdryer for like 3 min on high
Peter Tembo - Share
With hair dryer.
ZFix - Reply Share
Same procedure with Sony Xperia Z1? Where do i get the screen parts?
chrgro - Reply Share
Past 24 Hours: 5
Past 7 Days: 37
Past 30 Days: 383
All Time: 240,506
