Introduction
The Battery of the phone can become worn with continued use. This guide will show you how to remove the Battery of Sony Xperia Z1 Compact.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
12 other people completed this guide.
3 Guide Comments
is there any reliable source for good replacement battery purchase?
NFC Antenna. You should carefully transplant it to new battery, in case your new battery is without one (what is the case for most 3rd party batteries available)
