Sony Xperia Z1s Screen Replacement
  1. Sony Xperia Z1s Screen Replacement, Battery: step 1, image 1 of 1
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
  2. Sony Xperia Z1s Screen Replacement: step 2, image 1 of 1
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Screen Replacement: step 3, image 1 of 1
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Screen Replacement: step 4, image 1 of 1
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
  5. Sony Xperia Z1s Screen Replacement: step 5, image 1 of 1
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
  6. Sony Xperia Z1s Screen Replacement, Motherboard: step 6, image 1 of 1
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
  7. Sony Xperia Z1s Screen Replacement: step 7, image 1 of 1
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
  8. Sony Xperia Z1s Screen Replacement: step 8, image 1 of 1
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
  9. Sony Xperia Z1s Screen Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
  10. Sony Xperia Z1s Screen Replacement: step 10, image 1 of 1
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
  11. Sony Xperia Z1s Screen Replacement, LCD Screen: step 11, image 1 of 1
    • Using the T4 Torx screwdriver, unscrew the single 5 mm screw from the bottom left corner of the loudspeaker cover.
  12. Sony Xperia Z1s Screen Replacement: step 12, image 1 of 1
    • Slide the opening pick under the edge of the loudspeaker cover.
    • Gently lift and pry up the loudspeaker cover.
  13. Sony Xperia Z1s Screen Replacement: step 13, image 1 of 1
    • Use your fingers to slowly peel back the black flex cable in the middle of the phone until it is only connected at the bottom of the phone.
  14. Sony Xperia Z1s Screen Replacement: step 14, image 1 of 1
    • Gently slide the opening pick underneath the screen.
    • Lift the opening pick upward to remove the screen.
    • If needed, use a heat gun to loosen the adhesive holding the screen by aiming it around the edge of the screen.
Emily Scruggs
127 Reputation
1 Guide authored
Clemson, Team 4-4, Hunter Fall 2021 Member of Clemson, Team 4-4, Hunter Fall 2021
CLEM-HUNTER-F21S4G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 23
All Time: 251
