Sony Xperia Z3 Dual Battery Replacement
Video Overview
  1. Sony Xperia Z3 Dual Battery Replacement, Battery: step 1, image 1 of 2 Sony Xperia Z3 Dual Battery Replacement, Battery: step 1, image 2 of 2
    • Heat the back cover to soften the adhesive sticker.
    • Use the suction cup to open a gap from top side or bottom side.
  2. Sony Xperia Z3 Dual Battery Replacement: step 2, image 1 of 3 Sony Xperia Z3 Dual Battery Replacement: step 2, image 2 of 3 Sony Xperia Z3 Dual Battery Replacement: step 2, image 3 of 3
    • Insert into the guitar pick and slide to cut the sticker.
    • Remove the back cover.
  3. Sony Xperia Z3 Dual Battery Replacement: step 3, image 1 of 1
    • Release battery flex connector carefully to avoid breaking the pins.
  4. Sony Xperia Z3 Dual Battery Replacement: step 4, image 1 of 1
    • Get free that sticker which for fastening the battery.
  5. Sony Xperia Z3 Dual Battery Replacement: step 5, image 1 of 1
    • Pry up with a little effort because there is adhesive under the battery though not so strong.
  6. Sony Xperia Z3 Dual Battery Replacement: step 6, image 1 of 1
    • That's Sony Xperia Z3 Dual 3100mAh battery.
    • When you finished to replace battery and ready to assemble the phone, you need a piece of new back cover adhesive sticker because it's disposable and the old one can't use any more.
12 other people completed this guide.
Sophia
43,822 Reputation
62 Guides authored
2 Comments
Do you happen to know if the Z3 battery will also fit the Z3v i cant seem to find a replacement specifically for the Z3v
Victor Aguirre - Reply
Just finished this guide thank you!
Seb Carroll - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 28,222
