Sony Xperia Z4 Battery Replacement
  1. Sony Xperia Z4 Battery Replacement, Back Cover: step 1, image 1 of 1
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Sony Xperia Z4 Battery Replacement: step 2, image 1 of 3 Sony Xperia Z4 Battery Replacement: step 2, image 2 of 3 Sony Xperia Z4 Battery Replacement: step 2, image 3 of 3
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom left corner.
  3. Sony Xperia Z4 Battery Replacement: step 3, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 3, image 2 of 2
    • Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Sony Xperia Z4 Battery Replacement: step 4, image 1 of 3 Sony Xperia Z4 Battery Replacement: step 4, image 2 of 3 Sony Xperia Z4 Battery Replacement: step 4, image 3 of 3
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Sony Xperia Z4 Battery Replacement: step 5, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 5, image 2 of 2
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Sony Xperia Z4 Battery Replacement: step 6, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 6, image 2 of 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Sony Xperia Z4 Battery Replacement: step 7, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 7, image 2 of 2
    • Lift and remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Sony Xperia Z4 Battery Replacement, Battery Disconnect: step 8, image 1 of 3 Sony Xperia Z4 Battery Replacement, Battery Disconnect: step 8, image 2 of 3 Sony Xperia Z4 Battery Replacement, Battery Disconnect: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Use a pair of tweezers to carefully peel the adhesive strip off the mother board and the battery and remove it.
  9. Sony Xperia Z4 Battery Replacement: step 9, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 9, image 2 of 2
    • Use a pair of tweezers to peel the black adhesive strip off the battery connector and fold it out of the way.
  10. Sony Xperia Z4 Battery Replacement: step 10, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 10, image 2 of 2
    • Use a spudger to pry up and disconnect the battery connector.
  11. Sony Xperia Z4 Battery Replacement, Battery: step 11, image 1 of 3 Sony Xperia Z4 Battery Replacement, Battery: step 11, image 2 of 3 Sony Xperia Z4 Battery Replacement, Battery: step 11, image 3 of 3
    Buy
    • Use a pair of tweezers and grab the pull tab at the top right corner of the battery.
    • Pull out the adhesive strip with a pair of tweezers.
    • Make sure you pull out the strip in a slow and steady motion and in a flat angle. To prevent the adhesive strip from ripping, it is helpful to twist the strip around the tweezers.
    • In case one of the adhesive strips rips and it’s not possible to pull it out completely, you can use high isopropyl alcohol (>90%) and/or a heated iOpener to loosen the adhesive. After the adhesive is soft enough use a prying tool such as an opening pick, a plastic/playing card or a spudger to carefully pry out the battery.
  12. Sony Xperia Z4 Battery Replacement: step 12, image 1 of 3 Sony Xperia Z4 Battery Replacement: step 12, image 2 of 3 Sony Xperia Z4 Battery Replacement: step 12, image 3 of 3
    • Repeat the previous process with the adhesive tab next to the battery flex cable.
  13. Sony Xperia Z4 Battery Replacement: step 13, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 13, image 2 of 2
    • Use an opening pick to pry the battery out of its recess until you can get a good grip.
  14. Sony Xperia Z4 Battery Replacement: step 14, image 1 of 2 Sony Xperia Z4 Battery Replacement: step 14, image 2 of 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth before applying new adhesive.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (+90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
2 other people completed this guide.
Dominik Schnabelrauch
211,728 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 140
All Time: 13,975
