Introduction
Use this guide to remove a broken or defective LCD & Digitizer in your Sony Xperia Z4.
Opening the Sony Xperia Z4 will damage the waterproof seals on the device. If you do not replace the adhesive seals, your phone will function normally but will lose its water protection.
Due to the phone’s design, you must remove the lithium-ion battery to access the display cables. If the battery was deformed during removal replace it with a new one—reusing a deformed battery is a potential safety hazard.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before you begin, switch off your phone.
Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
Insert a fourth opening pick under the top left corner of the back cover.
Slide the opening pick along the top edge of the phone to cut the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Use the flat end of a spudger to pry up and disconnect the main flex cable connector.
Unhook and remove the metal shield above the loudspeaker cover located at the bottom left.
Use a pair of blunt nose tweezers to grab the flex cable between the charging port and the loudspeaker cover.
Carefully pull the charging port out of its housing.
Apply a suction handle near the top edge of the phone right under the earpiece speaker.
Use the suction handle to pull up the screen and insert just the tip of an opening pick under the right edge of the speaker recess.
Slide the opening pick to the top right corner to loosen the adhesive.
Leave the opening pick in its position to prevent the adhesive from resealing.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
